Hi
Every so often I turn on our Moment and whatever I want to listen to keeps "pulsing" and no sound comes from speakers, I remove the back and reconnect to the network, sometimes this works and we are back to normal. Sometimes it doesn't work and I have to turm the power off and back on again, it then asks to be reconnected to the network or re-establish a connection to the network, sometimes this works. Worst case senario is I have to do a factory reset to get it to work again.
We are currently using "Powerline Adaptors" I will try swapping them with the ones we use for our TV Youview box and see what happens, I will post back after testing.
If anyone else has had this fault I would be interested to hear what you did to cure it.
Cheers
