Avant speakers panel
The areas of the front panel at the level of the loudspeaker of my Avant are darker than the rest of the grille. There are two darker circles  that outstand to much from the rest of the panel.
Does anybody know how to clean those areas to make the entire panel appear uniform?
Regards
Very gentle vacuum cleaning has worked for me - with a soft brush attachment.
Dave
If you have a bath-tub , medium warm water with a bit of laundry detergent and let it soak for a while.
Make sure to dry the panel flat on a towel (or two) so that the fabric will not stretch
This worked like a charm for me.
Sorry, wrong post.
I've done the bath-tube+laundry detergent  technique and it worked wonders.  It looks like a new grey panel .Thanks
