Hi shaun, are your Pentas connected directly to the avant or to your beosystem 7000?
best regards
best regards
Hi Martin. They are connected directly to the Avant.π€And i use a ML/MCL amp to drive 2 beovox 3000 as rear surround speakers.πHi shaun, are your Pentas connected directly to the avant or to your beosystem 7000? best regards Martin
Hi Kiran. My Amp looks just like yours at the back. I remember that the the b&o guy cut some wires, but can't remember where...βΊοΈππ»I tried to do that. I too have the ML/MCL converter. Can you confirm the pins for the Penta cable on the converter has a 3 pint input. Did you have to cut 1 of the 4 pins on the cable? Regards Kiran Born in NL; I ride ML
If you want the Avant to switch on the ML/MCL converter, you need to switch 2 wires in one of the connectors. The yellow and the grey (Pin1 & 4).
That should work π
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
