Avant 75 + Beolab Penta?
Hi shaun, are your Pentas connected directly to the avant or to your beosystem 7000?
best regards
best regards
Hi Martin.
They are connected directly to the Avant.πŸ€—
And i use a ML/MCL amp to drive 2 beovox 3000 as rear surround speakers.😊
I tried to do that.
I too have the ML/MCL converter.
Can you confirm the pins for the Penta cable on the converter has a 3 pint input. Did you have to cut 1 of the 4 pins on the cable?
Here is some pics:
Kiran wrote:
I tried to do that.
Can you confirm the pins for the Penta cable on the converter has a 3 pint input. Did you have to cut 1 of the 4 pins on the cable? Regards
Kiran
Born in NL; I ride ML
Hi Kiran.
My Amp looks just like yours at the back.
I remember that the the b&o guy cut some wires, but can't remember where...β˜ΊοΈπŸ‘ŒπŸ»
Connection for Old school B&O to BeoLab Penta Mk. I
______________________
If you want the Avant to switch on the ML/MCL converter, you need to switch 2 wires in one of the connectors. The yellow and the grey (Pin1 & 4).
That should work πŸ‘
