Hi all B&O experts,
I have a very strange problem.
Here's my setup:
- Avant 55
- Beolab 11 subwoofer
- Beolab 12-2 front speakers
- Beolab 6000 rear speakers (detail the speaker cabels are linked so both speakers come together in one PL connection)
- Beolab 4 ceiling speakers
Sometimes when I select a speaker role with the beolab 6000 involved they make a soft siss and as a consequence no musical output. At one point I even thought the Beolab 6000 broke down so I replaced them with a second hand pair. However after a while the same issue started again. What makes this even worse is that I can't reproduce it. It just happens sometimes.
I tried all the following:
- I tried replacing the PL port for the beolab 6000 on the Avant
- I rescanned the soundconnections
- I completely shutdown the power for speakers and tv
This is the workaround I use with the highest success rate:
I made a music role with only the rear speakers and when it happens I select this role. I increase the volume real high (in the beginning this was around 70 but it seems as this barrier increases overtime so now's it's the maximum). Then after a while it comes alive full volume, you can imagine that this is not very pleasant way for me (and neighbours).
None seems to be the structural solution, please help ...🤔
