Avant 55 PUC control issue
LIve on the west coast and have not been able to find the correct PUC code. Trying to control the comcast X1 box...Does any one have suggestions?
Thank you.
There are no Comcast PUC's in the B&O library.
However, the box is going to be made by someone other than Comcast. You need to establish the box manufacturer, but my guess is that it will be Pace. See if your box has an actual model number on it.
If that fails, you could just try one of the Pace PUC's as most of them use the same IR codes for the basic controls
Thank you!
Thank you.
