Hi All.
This could be a tricky problem.
Until recently the configuration below worked. Let me define what worked means…. From any room I could select CD or Radio and the BS9000 would pipe sound thru any Masterlink or Network linked system (via the BLC), into the local speakers, whether they were connected to a TV or not.
It still does with main one exception. That is the entertainment room.
In that room from about a month ago……When I start the BS9000 by selecting CD from the Beo1BT remote. The BS9000 springs to life, the AVANT 55 NG indicates its joined to the CD but no sound comes thru the Avant's speakers. I can control the CD, forward tracks, change to another CD, but still no sound. Been driving me batty.
The BLC, looks to be configured correctly (works for the Horizon) and the BS9000's sound comes thru in all other rooms.
I just can't figure what has happened or what I can do to get sound from the BS900 working again in the Entertainment room.
All number or resets, power off's and more has been done. There is also an option in the Avant when you link a NM/ML convertor, to add sound to local speakers, This option can't be selected and I don't think it was before. Neither is it needed for the Beovision Horizon which can play BS9000 music.
B&O have no support perosn in Australia anymore so I am asking here if anyone could help?
Thanks Beoaus
Configuration is below.
Entertainment Room
Beovision Avant NG |
Connected to BL1's, BL4000's and a BL2 |
Connected to a solid stable flat WiFi network |
Connected to an Apple TV (latest Version) |
Connected to a Xbox S |
Linked to the ML/NL Converter |
Beosound 9000 |
Connected to Masterlink, Option 2 |
Living Room
Beovision Horizon |
Connected to BL8000's |
Connected to an Apple TV latest version |
Beolink Converter |
Connected to ML and NL (same flat network as the WiFi), in A.Slave mode, IR mode 2 |
Other Room
Beovision 7-40 MkII |
Connected to BL7-4 |
Connected to ML, Option 2 |
Other rooms have link speakers
