Avant 55
Hi Is there som One know how to set a audio output on a Avant 55 it is not for B&O speaker but only a signal to an Denon reciver
Maybe you can try to "tell" your Avant that the Denon receiver is a BeoLab xyz (look for a speaker that has the same characteristics as your Denon system (something between BeoLab 4 and BeoLab 5😕)). That worked for my BeoVision 8. But don't forget to start your Denon system at low volume. Cranking up ist easier than a repair.
You can choose LINE instead of a Beolab and it will then output a regular signal for your amp. I think there is one with volume control and one that is fixed.
