Hi Folks,
I have a Mk III Avant 32 DVD which I've owned nearly 10 years. The DVD Unit developed a fault in 2012 (which I posted at the time for some info re parts etc as B & O wanted £700 for replacement unit) whereby it wouldn't read the disc after loading.
I've bought a MK II for spares with a working DVD.
Is it simply a question of swapping out the DVD Chassis and Controller?
I have the service manual for the MK II and there doesn't appear to be any special instructions apart from ensuring the ribbon cables are correctly connected?
Any tips or advice please?
Mike
