AV9000 MasterLink Cable
I am in desperate need of a AV9000 MasterLink cable, I have tried connecting the CD player and TV by regular MasterLink but with no avail. Steve @ Sounds Heavenly tried to make me a cable and that didn't work! Liftestyle and MoreThan have scowered their stock room's and no body seems to have one!!
I therefore turn to the loyal BeoWorledrs to see if anyone can either offer up a solution to get the system to work with normal MasterLink or whether anyone has a spare cable that they would sell me!!
Any help is so greatly appreciated!!
What kind of cd player do you plan to use?
If its a B&O then the cd player goes through a Beomaster of some sort. The Beomaster then goes to Masterlink on the AV9000.
TV by Masterlink? I do not understand this part. What do you mean? Could you explain the complete setup?
On Beosystem AV 9000 there is a CD player in the Master control panel.
What I am trying to achieve is connecting the Master Control Panel (Ouverture looking CD player) to the AV9000 Television.
Eventhough the cable looks the same as ML it most certainly isnt and I really need some!
That's right I forgot.👍
Any B&O store should be able to provide such a cable?
No unfortunately the part in unavailable now so I am really stuck!
Can anyone help?????
Oh no!! Can't anyone source this??
Strange. I`m quite sure my old AV9000, the early two way version, and MPAV were connected by a regular ML-cable......(?) If I remember correctly, there are two Masterlink type plugs. First for connection of TV with control center, 2nd for MPAV and for link systems. Are you sure, everything is properly connected?
If this doesn`t help, there is an AV9000 expert in Germany, Ulf Kiener, a Beoworld member mainly in the german forum. Member name is "Ulf".
See also: www.ulf-kiener.de. If he can`t help, nobody can....😐
Good Luck
Stefan
Hi fishta,
I'm sorry that I couldn't locate a fully-wired Masterlink cable for you - I checked everywhere and I just can't get this type of cable any more.  This was only used by a few isolated B&O products including AV9000 for a few years and it used all 16 pins in the plug instead of just 9 with "normal" Masterlink cable.
It is worth noting that some versions of AV9000 will work with normal M/L cable, depending on the software level.  I can locate replacements for almost any B&O cable ever made, but unfortunately not the original "fully-wired" 16 pin Masterlink cable (although I will keep on trying!).
Kind regards,
Steve.
