Today! 😳
I installed the 1610, purchased 2 years ago. Time flies....
I have some troubles though. It is totaly worth it just to see that the telivision display says what track and what source I am playing on the bm7000, even when the telivision is turned off.
The TV and stereo is in the same room. But I am still confused about what option settings I should use. I have not found any information on what the setting on the television should be and how to change this. I have been trying randomly but it hapends strange things 🙂
I discovered one setting that made the cd player skip 2 tracks when pressing skip, and also the bm7000 started in mute and not in the preset volume... I have now lost track of all settings and need some advice. The positon switch on the 1610 is set on 3.
What I would like is that when I turn the TV on the Pentas starts as stereo speakers, and also the rear active speakers as surrounds. When I start the CD, only the pentas should start. Powerlinks to the pentas are now connected to the bm7000.
