AV9000 Audio Kit question
Hi all
I have recieved a question from a gentleman.. maybe someone can offer advice as it's before my time and above my head! I've never been asked this before..
"I have a Beosystem AV9000 television and a Beosystem 7000 audiosystem (BM 7000, BG7000, BG CD7000, BC 7000 and BL7000).
I would like to have them connected and integrated as one system.
I hope to be able to have 4 Beolab speakers connected to the AV9000 and be able to play CD/Radio etc, from the BS 7000
through the same speakers. I am not sure how the option settings should be configurated. All parts are in the same room.
According to this http://www.beocentral.com/products/av9000ak  and some information from the "old" Beoworld forum,
the AV 9000 Audio Kit was the way to go.
I am relatively new to the B&O world so I might be completely wrong here...
If so, what do I need? "
Can anyone shed any light on this for him?
Lee
The AV9000 audio kit set up guide is on site and it details the option setting and the way to run the cables. Essentially you set the 7000 to option 0 and set the switch on the audio kit to 3. He will need a 7 pin Audio Aux lead and a Powerlink lead run from the BM7000 to the Audio kit.
I think he needs the AV9000 ML converter to connect his AV9k to his BS7k... Its what I used when I had my 4500 connected to my Av9k but I connected the speakers to the TV and not the BS.
Only problem is that the AV9k link is unique to the unit.. I dont think you could use the normal converter?
I once connected my BC9500 to an AV9000-system, and this is they way to do it: Run the 7-pin audio aux cable from the audio system to the AudioKit connection box - then run an ML cable from it to the AV9000. You may also connect a powerlink cable between the AudioKit Connection box and the audio system, but it is not strictly necessary to do so. The AudiKit comes with an integrated option switch.
 You will be able to adjust bass/treble/etc on the 7000, but it will have little effect - so it is recommended to leave the controls alone and adjust everything on the AV9000. It can even handle timer play.
So, yes, you will need the AV9000 AudioKit. And the products will integrate much to the same degree as current ML products.
Roger
You can use 1610 or AV9000 Audio Kit.
This variant have 2 ML sockets, the 1610 only 1 ML and needs AC.
Ulf
Hello all!
I`ve an additional question concerning the AV9000 audio kit. I would like to integrate a Beogram in my AV9000 System with MPAV9000. The Problem is that it has no Datalink or Aux in! So is it possible to connect the 1610 via ML parallel to the MPAV9000 and on the other side of the 1610 a Beogram via Datalink? Is this a solution that might work or not? Thanks a lot! Chris
Sorry,
i don't think it works.
The MPAV in combination with the AV9000 is not connectable with an beogram
Ulf
Hello,
I am the "gentleman" refered to in the first message 🙂
Very impressing and fast response I must say,thanks to you guys i have answers on some questions I had not asked yet.
Does the settings Peter mention apply to the 1610 or only the "AV9000 audio kit" ?
Where do I find the set up guide?
I will probably get back with further questions, but one thing is sure. I will become a Gold member on this site!
Nice one Turbo. Glad you're impressed😁
If you're quick, you may still get the cherrished "f"  which makes you a founder member, one of the first 500 gold members AND entry into this months prize draw!!!
Andy T.
If you are a gold or silver member, the manual is available for download, along with the user manuals for the system. The settings are for the audio kit with switch. There are a couple of different sorts!!
