AV 7000.....V.AUX question
Hi....
On the AV 7000 there is the V. AUX.....could I connect in a CMM -10 CD changer there and operate it ....by pressing video...the way it works off tape 2 on say a Beocenter 9000????
There is no tape input on it....
 Thanks>>>
Yes - it should work fine. I don't have a CMM10 to test it with, but I see no reason why it wouldn't work...
Actually, the answer is no. The V-AUX port is only if you using an NTSC MX5x00 television.
okay...thanks guys....!!
