AUX not working on Beosound
Hello
I think the model of my player is Beosound 3000 from 1994. I want to connect my phone via AUX, but it does not work. I use a DIN to AUX cable but when I press AUX on the player, nothing happens...
What could be wrong?
Andreas Kaul
Hi Andreas,
Welcome to Beoworld!  Are you sure that you have the correct cable?  If not, this cable will be correct for your Beosound:-
Hi Steve, thank you for answering me :-)
The volume in turned to maximum on the phone, and I am pressing "AUX" on B&O keypad. I bought this cable :-)
Hi Andreas,
I can't vouch for the cable that you have, it may be faulty.  I test all of my cables before shipping, I'm not sure if the store that you used tests all their cables?
Kind regards, Steve.
Hi Steve
Thanks for your help - it is now fixed. The problem was that the phone waten´t on full volume. Again thanks for your help :-)
- Andreas
