AUX AUDIO BeoCenter 2500
I did a Beovision Avant connected with a BeoCenter 2500 by means of a Beolink Converter box. As a result the AUDIO AUX socket of the BeoCenter is in use (--> Datalink cable coming from the Beolink Converter box). This set-up works perfect.
But now I want to expand it with a BeoGram Recorders Deck (with external pre-amplifier). But where to connect it to the Beocenter 2500 ? There is no more AUX socket available. Is it possible to use an AUX splitter or expander ? Or will this create conflicts?
Are there any other possibilities ?
You could go into one of the scart inputs on the Avant... Scart can actually deliver a very good sound.
There is THIS which was made by B&O. It may be just what you are looking for. Where are you located as I have one, and you are more than welcome to try it out.
CraigπŸ™‚
you can use an AUX-Expander (6270345), you would only have to switch manually between the Avant and the Beogram.
( i already wrote that on the Dutch forum where you posted the same quesion earlier..  πŸ˜• )
 πŸ™‚
