Audio/aux link pin outs
Hi all
I need a datalink/audio aux link cable quickly, and the only one I have has had one end chopped off.
I am happy enough putting a new end on, and have found a diagram on beotech detailing the pin outs, but I don't know which colour cables relate to each function.
Can anyone help?
I don't think you should decide anything on the colours, they could be connected just about any fri*ing way depending on what mood the manufacturer was on. Measure them, or if you can slide the sleeve off the remaining connector, look inside it.
When I needed one, I could have made it up myself, but just decided to save myself the trouble of soldering and hunting for suitable raw cable, and bought one off eBay:
Over in North America, I ordered from this guy
http://myworld.ebay.ca/lazerwave/
and the data cable seems to be ok.
