Audio volume Tvix 6600 with BV7 mk3
A few days ago I've got myself a Tvix 6600 installed. It's connected by HDMI only, to my BV7 mk3.
I have to turn up the audio volume to very loud (>70) to hear the same as a TV-signal (volume of 50).
Can this be changed; settings Tvix or BV7 ?
Hi
I have turned up the volume on the TVIX to MAX (using the Tvix remote), and then it works just fine for me.
Hi Beolin,
Do you have the tvix 6600 as well?
Don't you control it via the puc-list / beo-remote?
Yes I do, and I control the Tvix via PUC, but you can increase the volume on the Tvix (no PUC code for that). I did that, as I before had to turn up the BV7 volume to 50-60, and now I have the volume at 30-40 on the BV7.
Beolin,
Do you use a beo4 or beo5? With my beo4 I can't seem to skip a movie to another chapter, or go to a "DVD's" menu to change subtitle or other settings....
