I’m a new member on this forum, and have the following question;
I plan to upgrade my audio by replacing my BL 8000’s for some ‘next step’ speakers like a set of used e.g. BL 9’s.
Any particular technical aspects I should be aware of if I buy them second hand; like specific defects and/or did they had a technical upgrade in the past few years?
I’m also considering a set used BL5's, but I wonder if in an 'average' living room (45m2) these speakers won’t be ‘over specified’ compared to the BL9's So do they fully justify the difference in price?
The BL's are connected to a BV 11.
Normal 0 21 false false false EN-US JA X-NONE
Thanks for your thoughts/advise
