Audio output from BS9000 via BV10 with PL connected speakers
Hi!
If a BS9000 is connected via ML to a BV10 which have 4 speakers connected via PL - does the BV10 then need to be turned on when playing music or can I assume that the ML will handle the speakers regardless of the BV10?
The tv will need to be powered on at the wall but does not need to be switched on to use the 9000.
Most of the commands are via the tv (except for the timer function).
NO, but only audio components of your BV-10 will power up and the LCD panel will still be completely off.
