ATV 4K and Beivision 11-55
I have an ATV 3rd generation, which fits beautifully in a compartment at the rear of the TV. Will an ATV 4K fit in the same compartment?
Quite sure they are the same size. Check on Apple webpage.
Double post. Sorry...
Yes, Same size. Easy googeling
Just to be clear, there are five generations:
2nd and 3rd are the same size.
4th and 5th(4K) are the same size.
Both the 4th and 5th generation have the touchpad remote.
I have the 4th generation and it does not fit in my Beoplay V1-40. Had no problem with the 3rd gen.
I have no clue if the compartment in the Beovision 11-55 is larger than the one in Beoplay V1.
Hi
Thanks for all replies. There is a difference in the depth.  Third generation is 23mm and 4K is 35Mm
Just wondering if there is anyone out there with an 11 who has bought an ATV 4K, and found it fits
The 4K Apple TV does not fit in that same nook... lol
I had to attach it the stb bracket
Replaced my old 3rd gen ATV with the new one in a BeoVision 10-32, a tight fit - but I got the cover to lock back in place and the new 4k ATV is out of sight.
Why did I put a 4k ATV in a 10-32? My local cable provider went from a small STB to providing an app for TV content - app only available on the new ATV.
Roger
Hi Gennaro and Roger
so one of you says it fits and the other that it doesn’t!  Where do I go from here?
Two different tv’s, though!
