AST dead?
Do any of the newer video products such as the BeoSystem 4 support AST? I don't see it mentioned any more. It also seems the discontinuation of the Beo6 would make it difficult to change listening positions.
-- Paul
Hi Paul,
The AST algorithm is not included in the the BeoSystem 4 (or BeoPlay V1, BeoVisions 11 and Avant). However, these products all allow for you to create up to 9 different "Speaker Groups", each of which can have it own:
- listening position (i.e. Speaker Level and Speaker Distance)
- Loudspeaker constellation (e.g. which loudspeakers are on and which are off)
- audio channel -> loudspeaker assignment
- name
Once these have been created for your listening positions and/or requirements (i.e. 2.0 vs. 5.1 listening in the same listening position) then you can switch between Speaker Groups in a number of different ways on different remotes. For example, on the Beo4, the two fastest ways are
- press LIST on the remote until the display reads SPEAKER and press the GO button to bring up the list of available Speaker Groups
- press LIST on the remote until the display reads SPEAKER and press the number of the Speaker Group you want to use
Hope this helps.
Cheers
-geoff
If you have questions about or problems with B&O equipment, these should be directed through your dealer and/or B&O's Customer Service department.
I cannot be a "short circuit", bypassing these communication channels.
-geoff
I’m trying to get my beo4 to list speaker group s but it won’t show any, do you know why?
Also can you use the ast with a beo5 instead of 6 thanks
