AST dead?
Do any of the newer video products such as the BeoSystem 4 support AST? I don't see it mentioned any more. It also seems the discontinuation of the Beo6 would make it difficult to change listening positions.
-- Paul
-- Paul
Hi Paul,
The AST algorithm is not included in the the BeoSystem 4  (or BeoPlay V1, BeoVisions 11 and Avant). However, these products all allow for you to create up to 9 different "Speaker Groups", each of which can have it own:
  • listening position (i.e. Speaker Level and Speaker Distance)
  • Loudspeaker constellation (e.g. which loudspeakers are on and which are off)
  • audio channel -> loudspeaker assignment
  • name
Once these have been created for your listening positions and/or requirements (i.e. 2.0 vs. 5.1 listening in the same listening position) then you can switch between Speaker Groups in a number of different ways on different remotes. For example, on the Beo4, the two fastest ways are
  1. press LIST on the remote until the display reads SPEAKER and press the GO button to bring up the list of available Speaker Groups
  2. press LIST on the remote until the display reads SPEAKER and press the number of the Speaker Group you want to use
Hope this helps.
Cheers
-geoff
PLEASE READ before sending me a Personal Message.
If you have questions about or problems with B&O equipment, these should be directed through your dealer and/or B&O's Customer Service department.
I cannot be a "short circuit", bypassing these communication channels.
-geoff
I’m trying to get my beo4 to list speaker group s but it won’t show any, do you know why?
Also can you use the ast with a beo5 instead of 6 thanks
