Are US tv wall mounts compatible with B&O?
Really silly question but I'm from the UK and have always had BeoVisions with the floor mountings. I moved to the US a year ago and just bought a house to move into come January with mountings for TVs in the bedrooms. Sure I could take the brackets down but I'd rather take the better option of just buying another couple televisions because you can never have too many devices 😕
But given the cost of moving (I have little access to credit over here) I can't really justify buying a bunch of new beovision+speaker setups on top of everything and I'll almost certainly have to go via eBay/Craigslist. Can I just buy any BeoVision flat panel and hook it onto the existing US wall mounting or does B&O use proprietary stuff on some if not any of its TVs?
Hard to give a general answer.
What Beovision are you thinking about?
Are the us tv mount VESA compatible?
I know there are VESA adapters available for e.g Horizon.
Apologies, I come at this from a floor stand veteran, and I guess that this is all just a matter of buying a $10 adaptor because there's only 2 (3?) standards in mounting. The B&O units I've had have had the square plates on the back, same as my computer monitors, then I saw the H-shapes thing on the wall and I was worried that this was one of these things where I'd get a panel, then have it sat out whileI had to go, buy more stuff and spend a bunch of time replacing+tidying existing mountings.
The only screens that can be mounted on VESA brackets were BV10/11 & BV4. The rest need modifications.
