AppleTV + Beovision 7-32 picture-issues
Hi.
I am having some issues with the picture - it is pulsating. It shows good quality picture for about 3 seconds at the time, then loses it for a fraction of a second, and then the cycle starts again.
I have tried to change resolution, but it has no effect on this.
The AppleTV is 3rd generation A1427, and works perfectly with another TV. The Beovision is type 9311. It is connected via HDMI-DVI-cable with no adapters.
I have not yet connected the sound and bought the converter, because I luckily started testing first if I could get picture through.
What could be wrong?
Have you tried cycling through all the ATV3's resolutions?  Press the MENU and UP button (on the remote) for 6 seconds, and the ATV3 will cycle through all resolutions at 20 second intervals.  Press PLAY to keep the one that you want.
Otherwise, it could be an HDCP (high-bandwidth digital content protection) problem - non-HD ready TVs will not usually accept an HD input with HDCP.  The HD audio extractor that I use (for ATV4 into BV26) has the added benefit of stripping out the HDCP, so the TV does not have any problems with the ATV outputs.
(EDIT: This is the extractor that I use:
I would try another HDMI source and see if it does the same thing.
I had a similar issue with connecting AppleTV to a BV6-23 with the same adaptor - in the end concluded that it didn't have the HDMI board - also what mark of 7-32 is it as others maybe able to help further define the problem.
Is your TV HD Ready?
http://bogo.custhelp.com/app/answers/answer_view/a_id/2646/~/which-bang-%26-olufsen-televisions-qualify-as-hd-ready%3F
Serial number min. 19135130 or upgraded with a special kit in the past….?
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096 Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55 Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL) Bedroom: Sony KD-65XH9077, Beosound Essence MK II with Beolab 6002 and Beolab 11 (all white, wall-mounted) Dart Room: BeoPlay V1-40 on floor stand Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Tried, but it pulsated on everyone of them.
My cable is this: https://www.belkin.com/us/p/P-AV10089/ The description says that it would fit to use with for example MacBooks, and it would not have audio in it - does matter? In any case this extractor sounds handy..
It was connected with this to Mac Mini, and it did not pulsate. However I could not watch for example Amazon Prime with it, because there was some sort of restriction regarding to the resolution of the setup. Everything else worked but Prime.
Ralf
It is less than that I am afraid. I was told earlier that it would be HD-ready. You think this might be the reason for the pulsating? It seems however that ATV has been successfully connected to older models than this or have I misunderstood something?
How to check if it has been upgraded with that kit?
[quote user="Guy"]
I think I have the same configuration,: Apple TV 4  bv7-32! HDMI goes direkt to The DVl plug
I tryed the converter:
https://www.amazon.co.uk/gp/product/B00NAJ4UM2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I've got no picture and no sound!
Then I try this converter:
https://www.amazon.de/gp/product/B07FX6C7TP/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
And have a good HD picture and good sound.
TOH wrote:
The extractor has a mini-USB-USB-wire, but no power source was in the package as the guide stated. I tried to connect one, but it had no impact - what is it for?
This USB port is for extern Power and just be connect to a 5Volt powersupply!
Best regards
