Apple TV4 to Beovision 6 26" MK1 - no sound
Hi.
Looking for some help.
I have an older BeoVision 6-26 MK1, where I have connected my Apple TV4 on the DVI input (PC) - and picture is OK - but sound is missing.
To get audio/sound I have tried a HDMI-to-HDMI+audio converter to extract the Audio L/R - but where to feed in the audio and how to select the audio-source input when on DVI (PC) ?
Setup:
BeoVision 6-26 MK1 (Type 9250) with no surround module - have no manual showing the connection
Apple TV4
HDMI converter
Best Regards
JD8680
Welcome to Beoworld!
I have this same set up but with a slightly newer BV6.  Are there not PC sound inputs in the side of the central connection panel?  Red and white phono sockets?  This is what I use and it works well.
thx for feedback
Have tried the red/white phono sockets on the upper left side in the connection panel - but still no audio. 🙁. - Do i need to make special source selection ?
Guide/Manual on B&O homepage support site is for newer models and not the 925x
Best
JD8680
No - this should just work when you select PC from the Beo4 LIST.  Have you tried the audio extractor output into another amp to check that it is working?
EDIT:  Do you mean the red/white connectors in the CAMERA panel just behind the top left of the screen (with a separate yellow connector for video)?  This is incorrect - there are other PC audio inputs in the main connection panel in the back.
No I tried the two phone close the antenna and mains inlet.
Will try to connect to an amplifier to see if the HDMI boks audio out is working - or maybe I could just connect to camcord and select that source for the audio test - but they maybe is mutes due to not sync.
Or just press your thumb to the 3.5mm socket plug that normally goes into the audio extractor and see if you get a hum from the TV.
It doesn't mute - you should get audio as long as you select CAMERA
Think the Audio out on the box is the problem.
if I pull out the audio cables from it and "touch" the open connectors - I can hear humming sound in the TV speakers if I turn the volume up - so probably there is no audio coming from the box.
It has 3 settings - pass/2ch/5.1 - same on all 3.
Will try to get a new one and try.
Mine's one of these and it works well:
OK, thx - maybe I will order similar.,
The one I have looks like this one :https://www.amazon.co.uk/ViewHD-Audio-Extractor-Converter-Model/dp/B00KBHX072?pd_rd_wg=6uFXt&pd_rd_r=795e95e4-8135-4f3f-a391-3631cae37d0c&pd_rd_w=6AwYn&ref_=pd_gw_simh&pf_rd_r=PS3JZGX2JWR9AAB1S3AD&pf_rd_p=14f91171-0541-58ad-938b-3aec945f4cb7
