Apple TV vs Archos TV+
anyone used either?
I'm thinking of Archos at the moment through a BV8 linked to BL6000's.
not too bothered about streaming. However does anyone know if you can use the Archos remote whilst the main unit is hidden away?
Sorry, no idea - but I suggest to take  a look at the Popcorn Hour. This should be in the PUC list.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I kind of agree, PS3, ATV or popcorn .... somthing like that ... while would you introduce Archos if the BV can control the earlier ?
Do you mean that Apple TV can be controlled through the BV using Beo4 /5 ?
If thats the case, then its a no brainer
Yes, ATV can be controlled by Beo4/5. I have a similar set-up to what you are considering: BV8, ATV, Tivo, BL3s. Everything is controlled through a Beo4 via the BV8 ir blasters and all boxes are hidden from view. Very clean.
Hello B&O in Denmark. Obviously you are not advertising the merits of the STB concept enough.
