anyone used either?
I'm thinking of Archos at the moment through a BV8 linked to BL6000's.
not too bothered about streaming. However does anyone know if you can use the Archos remote whilst the main unit is hidden away?
anyone used either?
Sorry, no idea - but I suggest to take a look at the Popcorn Hour. This should be in the PUC list.
Ralf
I kind of agree, PS3, ATV or popcorn .... somthing like that ... while would you introduce Archos if the BV can control the earlier ?
Do you mean that Apple TV can be controlled through the BV using Beo4 /5 ?
If thats the case, then its a no brainer
Yes, ATV can be controlled by Beo4/5. I have a similar set-up to what you are considering: BV8, ATV, Tivo, BL3s. Everything is controlled through a Beo4 via the BV8 ir blasters and all boxes are hidden from view. Very clean.
Hello B&O in Denmark. Obviously you are not advertising the merits of the STB concept enough.
