APPLE TV TO AVANT
My local retailer said its not poss but my mate says it is.
Huh?
Confused at the moment. Is it possible and if it is, what do I need?
Cheers
Who to thrust πŸ˜‚
It used to be possible by converting the component output of the AppleTV to a RGB signal (these types of converters can be bought for less then 100 euro).
But I am not a 100% sure because I recently read some comments on the internet saying that the appleTV adds a signal to disturb this conversion. Solutions seem to be downgrading the AppleTV firmware.....
But as said: All this information is not from own experience but from reading on the internet (what led me to the conclusion to wait until I have a tv with component or HDMI input before I bu a apple TV).
Good Luck,
Bieele
You can buy a component-RGB converter, you loose some of the picture quality, but it is possible :)
To use your Beo4/5 to control the apple tv box, you need a SW update ( change of an IC) and an Ir cable.
I use this hack and it works just fine,
http://www.youtube.com/watch?v=84lRorvaAvk
If the power is lost you have to make it again,
otherwise it works great!!!
and itΒ΄s much cheaper
