Hi there,
I've upgraded to iOS 13, with a nifty side menu that is accessible via the 'TV-button' on the Apple Remote. Can be used to switch user profiles and do a quick search. Does anyone know if we can expect a PUC-update to access this menu?
Hi there,
As it implies adding a new button to the PUC, the answer is probably "no" for old PUC TVS and "maybe in 10 years" for connected TV where you can update the PUC yourself...
On my side I noticed that since TVOS13, the Apple TV doesn't with on anymore, I have to use its remote... But I can still control it via PUC (and Beoremote) once it is on. Any setting I forgot to change since the update?
(BV14) I have no issues at all controlling the AppleTV 4K on tvOS13with my BeoRemote One BT!
Karel.
I'm finding that since the new Apple TV update that sometime --- but not always -- that the "go" and "back" beoremote buttons will not wake the Apple TV out of sleep. Rather, I have to press the "green" beoremote button for the menu command to bring it out of sleep.
If I press “Home” on BR1 (having selected ATV first) the ATV menu is shown on the left part of my BV11 screen. From there I can turn on the ATV by pressing “3”.Same issue here. I can no longer wake the ATV from sleep. I tried “green”, but doesn’t work. Any ideas what to try? What works for you?
Both my ATV’s (a 4 and a 4K) come on when I press the associated button on my Beo4.
The ATV’s and the PUC’s are updated to the latest version.
