Good afternoon guys!
Thanks to your help I managed to remove the front grill of the Beosound 3.
Today I also get a power supply, so while waiting for answer on the Beogram thread I start toplay with the radio.
Thanks to CB, I already knew the keypad was to responsive or so little…
After removing the grill and disconnecting the little ribbon cable and spring I could lift the keypad.
Login to view image
Login to view image
I followed the instructions on the forum and generously sprayed it with contact cleaner. But it didn't change anything.
Then dead for dead I tried the other solution commented in this forum too.
I heated the keypad with an hairdryer for 1-2 minutes and start to peel the top panel foil with a thin blade.
Proceeding with caution and little by little and trying to not cut the plastic foil with the electric tracks it can be done quite easily.
You need to peel it with care to not bend or dent the top foil sometimes heating it again.
I peeled/stick back the top foil numerous times in my attempt and it did not broke or bent.
Once removed you have the thin foil with the buttons:
Login to view image
And the top plate base, with the plastic foil and the black plastic hook underneath
Login to view image
I cleaned all the button cells with alcohol and it was obvious they were dirty: you can see in the top picture that the two buttons (2 lines in a circle) around the aerial hole are clean where the other button have a brownish disc around. The volume touch pad was generously wiped too.
You have to clean the discs where the button are and also the black squares which I believe, do some sort of contact for the touch function.
I cleaned the thin foil bottom too where they need to contact the printed circuitry.
Login to view image
I didnt wipe all the glue because I'll need it to assemble the two part of the top panel together. The tricky part is then to make the cells very clean without smudging the glue around.
I place it all together (with no obvious traces of the opening) and powered up the BS3.
I was able to recover like 70% of the touch function. I can't say if its because the cells are not clean enough or something was damaged in the process.
Some functions still respond erratically and tracks on SD card keep skipping without even starting. I dont know if its because a "stuck contact" or anything else. The touchpad also seems to have become a force-touchpad where you need to press a little for it to register the control.
I may try to clean all the foil deeply, removing all the old glue but i need to find a way to sick the foil to the base in a non permanent but steady way.
Also need to investigate that SD card problem. For tonight I can set the time, power on and off the device, navigate stations and set the volume… All is needed is a little patience or "tour-de-main"!
Hope this helps.
