Am still struggling to get the BS3 (Mark 2) and BV4 working after months of frustration :(
Is there a kind soul that can confirm the IR sensor name located on the PCB under the half round plastic top cap. There is a fine print on top of the sensor. Not sure if TSOP 2136.
I have tried a TSOP7000 (with different pinouts) but didn't work and not sure if due to incorrect sensor or other fault.
I would consider to buy a sensor or whole pcb if I get any feedback.
[View:http://imageshack.us/photo/my-images/6/irsensor.jpg/:800:0]
Regards,
