Antenna-signal through a BV 10
Hi forum, I have connected my BV 8-32 to a BV 10-46 both with Masterlink and antenna. Before I had a BV 7-32 in the same place of the BV 10-46 and it seems like the BV 10-46 blocks the pure antenna signal, earlier I could press TV on the 8-32 and see TV with the antenna signal, but not now.
I also have the B&O RF amplifier and maybe I can use it to send the antenna signal through to the 8-32?
Would really appreciate some help.
Best regards
Hans
The RF amp handles this if connected properly
OK, I hoped that the RF amp could help. Attaches a drawing of my rooms with B&O-equipment, could you or someone else please help me how I should connect everything?
BR
Hans
I have one so I can try to help
But there is some fault in your message and the link to your picture is not showing properly
