Announcing Beo5 3rd Party XML Generator Verison 1.1.0 is now available
Jacob (Weebyx) and I are pleased to announce the availability of "Beo5 3rd Party XML Generator Version 1.1.0.1"
This version has been introduced to allow members to use the new version of Lintronic software released by them on 3rd April 2009.
This version will detect both old and new versions of the Lintronic output and if you wish to add text files created from the new Lintronic software into a directory with existing files, then that's no problem. The program will check each file to determine which format has been saved.
Silver and Gold Members can download the new version from the Beoworld site
Is there any chance of more screen shots. I'd like to have an idea how easy this is to use, i'm a bit of a dummy, and screen shots would hopefully give some explanation of what level of knowledge is required.
Regards
H1
Anyone can download the help file
Hello Keith,
I do not quite understand that you have not contacted me when developing this excellent program, to ensure future compatability.
Example: There is a minor issue reading the format when I enhanced the timing control.
Furthermore we could make use of the thousands of products already in our database.
I would be more than happy to cooperate.
Furthermore I think the program should be available to everybody.
It could be integrated into the Configurator.
Rgds,
Michael Lindgaard.
Hi
Is there a help file for the Beo5 3rd Party XML Generator. Im new to this and trying to find out how to connect my Philips LCD TV and Samsung HDR to my Beo5.
Brg.
Martin,
You can find the help file
Hi.
I just bought a Beo5 to get rid of all remotes that I have.
Samsung Plasma
Thomson IPTV
Boxee Box
Sonos-system (problably not able to remote this as it not using IR at all).
I bought the silver membership to get your wonderful tool.... buuuuuut... the helpfile isnt working for me.
Im kinda in the dark now. Cheers!
edit: got it to work.. time to learn some new stuff :)
The XML Converter Tool found on Beoworld only converts Lintronics timing codes to RAW encoding in the XML file meaning that some functions may not function 100% as original. However, you can use other facilities such as "Bitstream" which will provide you with almost 100% perfect results.
The main exceptions mostly relate to Philips protocol such as RC6 because they toggle bit 3 of the IR sequence for each press of the same button.
The older Philips RC5 protocol which also toggles bit 3 of the IR sequence is fully supported in the Beo5/6 firmware and works well. The 3rd party XML tool found on Beoworld can convert known RC5 address and command codes into a working XML file.
Ok.
Im trying your tool now, but its giving me a hard time.
Found a older version of the Lintronic config tool to convert the Pronto hex to your tool.
For this im trying to set up my IP-TV box...
Doing a lintronic device file named "THOMSON, STB, IPTV" and its containing this.
0=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730057300573005730057300573005730057300573005730057300573005730057300573016930057301693005730169300573016930057301693005730169300573016930057301693005734400609040022660057397626
1=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057301693005730057300573005730057300573005730057300573005730057300573005730057300573005730057301693005730169300573016930057301693005730169300573016930057301693005734400609040022660057397626
2=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730169300573005730057300573005730057300573005730057300573005730057300573016930057300573005730169300573016930057301693005730169300573016930057301693005734400609040022660057397626
3=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057301693005730169300573005730057300573005730057300573005730057300573005730057300573005730057300573005730169300573016930057301693005730169300573016930057301693005734400609040022660057397626
4=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730057300573016930057300573005730057300573005730057300573005730057300573016930057301693005730057300573016930057301693005730169300573016930057301693005734400609040022660057397626
5=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057301693005730057300573016930057300573005730057300573005730057300573005730057300573005730057301693005730057300573016930057301693005730169300573016930057301693005734400609040022660057397626
6=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730169300573016930057300573005730057300573005730057300573005730057300573016930057300573005730057300573016930057301693005730169300573016930057301693005734400609040022660057397626
7=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057301693005730169300573016930057300573005730057300573005730057300573005730057300573005730057300573005730057300573016930057301693005730169300573016930057301693005734400609040022660057397626
8=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730057300573005730057301693005730057300573005730057300573005730057300573016930057301693005730169300573005730057301693005730169300573016930057301693005734400609040022660057397626
9=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057301693005730057300573005730057301693005730057300573005730057300573005730057300573005730057301693005730169300573005730057301693005730169300573016930057301693005734400609040022660057397626
BACK=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057301693005730057300573005730057300573005730169300573005730057300573005730057300573005730057301693005730169300573016930057300573005730169300573016930057301693005734400609040022660057397626
DOWN=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730057300573016930057301693005730057300573005730057300573005730057300573016930057301693005730057300573005730057301693005730169300573016930057301693005734400609040022660057397626
GUIDE=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730057300573005730057300573005730057300573016930057300573005730057300573016930057301693005730169300573016930057301693005730057300573016930057301693005734400609040022660057397626
LEFT=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057301693005730169300573005730057301693005730169300573005730057300573005730057300573005730057300573005730169300573005730057300573005730169300573016930057301693005734400609040022660057397626
NEXT=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730057300573005730057300573005730169300573005730057300573005730057300573016930057301693005730169300573016930057300573005730169300573016930057301693005734400609040022660057397626
OK=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057301693005730057300573016930057300573005730169300573005730057300573005730057300573005730057301693005730057300573016930057300573005730169300573016930057301693005734400609040022660057397626
POWER=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730169300573005730057300573005730169300573005730057300573005730057300573016930057300573005730169300573016930057300573005730169300573016930057301693005734400609040022660057397626
PREVIOUS=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730169300573005730057301693005730169300573005730057300573005730057300573016930057300573005730169300573005730057300573005730169300573016930057301693005734400609040022660057397626
RETURN=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730169300573005730057301693005730057300573005730057300573005730057300573016930057300573005730169300573005730057301693005730169300573016930057301693005734400609040022660057397626
RIGHT=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057300573005730057300573016930057301693005730169300573005730057300573005730057300573016930057301693005730057300573005730057300573005730169300573016930057301693005734400609040022660057397626
UP=F0038R0003090400450700573005730057300573005730057300573016930057300573005730169300573016930057300573005730057300573016930057300573005730169300573005730057301693005730169300573005730057301693005730169300573005730057301693005730057300573005730057300573005730057300573005730057300573005730169300573005730057301693005730169300573016930057301693005734400609040022660057397626
When trying to import this into your tool it crashes.
These commands are neither Pronto HEX codes or Lintronics Timing codes.
If you have the Pronto codes, then just post those and I will convert them for you.
