Announcing Beo5 3rd Party XML Generator Verison 1.1.0 is now available
Jacob (Weebyx) and myself are pleased to announce that the Beo5 3rd Party XML Generator version 1.1.0 is now available for download to silver and gold members link
This version has a pull down to define the version of firmware loaded in the Beo5. It supports the current version 1.40a which is only available with version 2.20 of the Beo5 Configuration Tool and the previous firmware version.
Below is a screen shoot showing the updated area.
Congratulations to both of you. What more can I say than a big BRAVO!!!!!!!
Keep on the good work!
Thank You very much, Keith and Jacob for the work you both are doing here.
Best regards
Hi Keith & Weebyx,
Thanks a lot for all the time you put into this!
Cheers,
Frank
Let me say right away, I can't afford the Beosound 5 and am not technically knowledgable enough to understand this thread. However, what I can't understand also is why this work is neccessary when surely B&O should be providing this, especially for such an expensive product!
Now feel free to beat me down!
In this case Beo5 is the handheld remote controller not BeoSound5 (BS5) 😁
Frank
Hi Keith,
I just tested the tool just now and it does also fix the issue with the long pauses that I had previously, so no more manuals edits for these 😐. Bravo!
Frank
Frank
Thanks Frank, that's one thing I did understand. I meant the Beo5! Same point though!
Hi!
Can you please give a free link to the new manual like you did with version 1.0?
I would like to read it before I buy.
Thanks in advance!
The new help guide with version 1.1.0 is exactly the same as the previous version except it shows a picture as shown on the first posting of this thread where two pull downs have been added to select the firmware being used and the carrier frequency of the infra-red signal to the third party device
