Android update
My Avant NG just asked me to restart because of a software update. Anyone know what’s in the update?
HI if you go into android setting it tells you all also updates remote 1 and advises you might need to change your batteries as data base updates but shows it on your remote screen
m welborn
Mine did that too - nothing seems to have changed...
best regards Elmar
m welborn
It only says improvements and updates to the remote. Not exactly informative 🙂
Horizon was also updates and  Beoremote One.
and now BR1 gets updated every time I switch off the TV....
