I owned a Beoplay A9 2nd gen for almost 2 years, but I recently encountered some connectivity with my Android devices (a phone and a tablet) since October.
All the iOS devices are able to connect to the A9 easily, whereas for Android devices it prompted the following message:
Failed to connect
Unable to connect to BeoPlay A9. possible reasons are:
1. Bluetooth is disabled on the device or the device is not within range (10m)
2. The device is already connected to another device. Please terminate that connection and try again.
The fact is I was standing next to A9 and no other devices are connected to A9. When i turn on the Bluetooth on iPhone, it is easily detected and connected.
There is only 2 ways I can get connected to the A9:
1. Hard reset
2. Turn off the power completely for 1 min, and power up again.
By using the method above, I will pair with the Android devices again, this will work but after I turn off the Bluetooth, the same things happened again!!
The Wifi work completely fine, I have tested through Spotify via both iOS and Android devices.
I am not sure if you have encounter some issues before, BEO technical support said it could be the board issues, but I seriously doubt so, otherwise the iOS will not be able to connect, and hard reset will not work either.
The firmware is 1.17.24101.118790503
Please advise
