Am I getting the best sound? BeoSound Core\TIDAL\Airplay
Greetings, my friends. I’ve been lurking on the forum for a long time but this is my first post.
I have a question about my setup. I have a BeoSound Core driving a pair of Beolab 17s (which I love, by the way. John at B&O Manchester is totally right—the 17s are underrated; such great bass!).
To listen to MQA-quality music I stream from TIDAL Hifi. I open the TIDAL app on my iPhone or iPad and then connect to my BeoSound Core via Airplay (2). I have the app set to stream Master quality audio over WiFi.
Unfortunately, the B&O app does not have native support for TIDAL as it does for, for example, Spotify so using only my iOS devices and the gear mentioned, this is the only way I know of to get TIDAL to my Core. I wonder if I am getting the best quality audio possible over Airplay (2). Can anyone confirm?  Can Airplay (2) stream the hi-rez music from TIDAL in the best quality possible and can the Core process such a feed via AirPlay (2)? Thank you!
(Also a plug for suggesting B&O incorporate native support for TIDAL and Qobuz in their app!)
MQA does not transmit over AirPlay.
Have you tried Deezer HIFi?
Beo app support that natively.
Thus, there is no way to get TIDAL MQA wirelessly to a BeoSound Core using an iOS device?
Does this not seem inherently wrong...?
Thanks for the response, both of you!
Apologies for the double-post. Mods, please delete the duplicate.
It appears I need to purchase a Bluesound Node 2i and sell my Core. Shame B&O won’t integrate native high-rez streaming services into their software.
MQA not transmitting over airplay seems to me to be an apple thing, not a B&O thing
Curly wrote:
I hope this helps! I certainly learned a lot. Thanks, all!
There might be a lot more to learn about MQA.
You could start here:
Archimago has posted a lot about his findings about MQA (since day one).
Also this might be helpfull, if you want to avoid being the cashcow of the modern audio industry:
link
These two guy are some of the very few ‘rational audiophiles’ in the audio press today.
As far as I know B&O they seem to be in that camp too.
P.S.
I’d be much more interested in the provenance of the files/the music - and what has been done in the chain up till the point where you get to buy/stream them - than in the delivery format.
Long live the CD specs....they cater for all that human beings need for listening to music and what our audio gear usually can handle - be it as a disc or as a stream.
That is so true. Close friend of mine who works in audio/video  (actually he is an encoder) has been saying the same thing for a while now...👍🏼
I purchased a Bluesound Node 2i after reading very positive reviews. This product has native support for all the high-rez streaming services, so I will not have to use Airplay and therefore can get sound quality better than Airplay’s max CD-quality of 44.1/16.
I will post back to note if I can hear differences on my BL17s between 44.1/16 (BeoSound Core) and 96/24 (Node 2i).
