Hi everybody,
I'm looking for a (cheaper) alternative to Powerlink mrk3 cable, is the an alternative or do I have to go for the (expensive) original B&O or BOSSCOM cabel?
Best regards
Rasmus
Hi everybody,
Best regards
Rasmus
I wouldn't really want to go for anything cheaper. If anything, I'd see if you can get some 8/8 PowerLink (the kind supplied with BeoLab 5s).
Hi Rasmus,
If you look on eBay, you will see that there are now several other brands of cable available that are compatible with Powerlink mark 3, other than B&O and Bosscomm.
Best regards,
Steve.
