Almando multiroon
I have installed the multi room surround sound with lg c9 55" connected via earc to the almando, and beosound 3200 via powerlink, hi-fi works fine and can be controlled from beo4 on, off volume up and down. LG tv does work with lg remote but it's slow to respond to commands for volume, I wondered if anyone has this box and what their experience is, can you use the beo4 and get the sound from the tv to work with beosound 3200?
Hi boskonay
Can you tell me your set up, do you have a bang and olufsen hifi in your setup, the problem I'm having is volume control with lg tv, its connected hdmi on earc into almando, it just seems slow to respond, also what settings did you use for volume in the almando app for tv, help would be appreciated
