I'm swapping my BV10-40 for a BV11-46 and thereby need to join my exiting ML network with NL.
I have discussed with my dealer but I would like the Forums advise as well.
This is my planned setup:
New stuff I plan to add, apart from the BV11:
- Beolink Wireless. That bit is cabled today but it does not look so good.
- NL/ML converter. Obviously needed and part of the deal I´ve done for the BV11.
- Delay box. I will play music on the BL2000 and the BC2 simultaneous, and the delay box will fix that as I understand it.
Some questions:
- Is it okay to build a network after a Beolink Wireless, or are they intended to use just to connect directly to e.g. a BL3500?
- Can the delay box be "tuned" or is it a fixed delay?
- Is someone using powerline adaptors between the BV11 and a router when using NL/ML converter. Does it work well?
Any experience out there that I need to know, or general advise would be awesome.
