Advice needed on connecting BV10-40 and BS4
Thank you for an excellent forum. A bit novice in the Bellini world, so I would try to get some advice.
I have a BV10~40 with a pair of BL6000 and a BL2 connected to it AND a BS4 with BL8000 and BL4000 connected to the BS4, The two sets are both located in my living room.
Today they are working as two separate systems. I would like to be able to play music from my BS4 and also have sound from the BL6000, TV and BL2 to take advantage of the extra bass from the sub when playing music. There is no need to have TV sound playing in the BS4 speakers.
The two systems are already connected via master link.
2 questions:
Is this possible or do I need additional equipment?
I assume the Option programming plays a part. Anybody that could advice me of which A.OPT and L.OPT I should use?
All help and tips greatly appreciated
This should help you - page 10/11).
The easier way however, would be to read the guide of the tv - page 39:
link
Postet an answer for you....but it went into moderation - for whatever reason ;-(
Stay tuned - it will eventually turn up.
Thank you. Very strange wrt moderator
