I use beoremote one bt with Apple tv and cant find a Way to adjust the Sound. Is it possible?
Adjust Sound on Apple tv 4K with beoremote one BT
Isn’t the TV controlling the volume? Why would you want the Apple TV to do it?I use beoremote one bt with Apple tv and cant find a Way to adjust the Sound. Is it possible?
What exactly do you mean by “adjust”. Just volume or other settings?I use beoremote one bt with Apple tv and cant find a Way to adjust the Sound. Is it possible?
i want beoremote one to take full control of apple tv so i only need to use one remote. But I can not get it to control the sound on Apple TV.
The Apple TV sends audio and video to your TV. The volume is controlled on the TV. The beoremote one needs to control the TV.
@DD72
Please describe your setup!
Otherweise it will be tough to give an advice.
Yep, this has confused me, too. I can even 'adjust the audio' via my LG GX and BeoRemote One and the remote has very limited control over the Apple TV via the TV itself.
