Adding extra speakers
I've been having a play around with my BeoVision 7-40 MK V because despite my beolab 7.2 being an amazing speaker I miss having surround sound.
I have an old Bose Acoustimass 3 active Sub which has a pair of passive cubes attached to it. So I connected up the sub by 5 Pin Din to Phono cable into the Bose Sub and told the TV it was a pair of 8000s as it has the crossover built into the sub. All worked but the sub buzzes. The cable is fine as I used it to test using it as an aux cable into a B&O Hi-Fi and there was no buzz. So I tried plugging my iPhone into the sub with a 3.5 to Phono cable. No buzz.
Is this just a bad combo or has anyone else got similar or any other ideas? I would buy some BeoLabs but would only want a BeoLab 3 2 combo or BeoLab 9s which I just cant afford at the moment!
Cheers
I would suggest that this is an earthing issue. To start with, try earthing the aerial feed to the TV.
There is no aerial going into the TV just Sky HD so I can't think what it is!
It can be the Sky dish - try earthing the feed.
