Adding a second CD Player to a ML system - HOW
Feel silly asking this but I'm sure there is an answer... So I see that Beo4 has a CD2 function, am I therefore able to add a second CD source to my ML system. Already have BS9000 as an audio master in the living room but I wanted to also add a Beocenter 2300 which is upstairs. Would like to be able to select either unit from any room whiich I'm guessing is via CD or CD2. Only problem is I can't find any ML setup instructions "A.OPT" to set the second source (BC2300) to respond as CD2 from Beo4 (via a link room). The whole thing will be further complicated by me using a Beolink Wireless with a Beolink Converter daisy-chained in order to be able to both connect the Audio Aux Link from the Beocenter to the ML and add the unit to the ML without laying new cables !!! phew. So how do I make something be a "CD2" ? Any ideas welcome.
As an ex-B&O installation/service engineer, I don't think there is any way to do it unless you use a DVD source, such as a DVD1, Avant, BC1, BC2 (maybe a  possibility?) etc. I think you will find some ML conlflicts if you try it!
Sorry I can't help you further but as I understand it there can only be one audio master on a single link system, except for the circumstances of a Beocenter 2 or Beosound 5, maybe someone on here can prove me wrong?
Using a DVD as a 2nd source via the TV-master is an option.
An alternative solution that will fulfil many, but not all of your wishes, could be:
BSd 9000 in "A.OPT 0 / 1 / 2" remains the audiomaster for the whole ML system
Upstairs a BeoLink Active in "L.OPT 4" accesses your main sources (the BSd 9000) via ML
BC2300 in "A.OPT 1" is connected via a specially configured cable (Sounds Havenly) to the
"PC" socket of a BeoLink Aktive (as a local source).
Upstairs, selecting "LINK" from "LIST" and pressing "CD" or "RADIO" will access the BSd 9000
whereas selecting "L-PC" will activate the local PC-socket on the BeoLink Active and subsequently
pressing "CD" or "RADIO" will send the sound from the local BC2300 the Speakers connected to the
PL-Out of the BeoLink Active
Alternatively (if there is no need for remote controlling the BC 2300) you can set the BC 2300 to "A.OPT 0"
and the BeoLink Active to "L.OPT 5 or 6".
This avoids the necessity to press "LINK" to control the BSd9000.
