Hi Forum
Will my old Beomaster 4500 be able to use newer speakers like Beolab 4 and Beolab 3500?
Hi Forum
Welcome to BeoWorld!
To answer your question - Yep!
I think fully wired MK2 would be the best bet?
pl = Powerlink
Depends on the speakers rather than the 4500 as to which cable you will need. They will all work though.Speakers with ICE amplifiers need cables with more screening.
Thanks for quick reply.
Do I need Mrk II og Mrk III cabels?
What would you prefere as a small speaker for BN4500?
Well, technically, MK3 if you want BeoLab 4.
I'm sure MK3 is backwards compatible, so go with that one.
As far as active (BeoLab) speakers, any are approprite. Whatever is best for your space and for you. The usual suspect around here is the BeoLab 3000. But those can be a bit large still and limited to wall placement. A LOT of people like the 4000 which is quite compact. There are a bunch of options...
