The Beolab 5 must be in option 1 to receive the Beo 4 remote signal to do the pin code. You can use the Beo 4 to change the option number. You then need to reset it to option 0 if you are using the speakers with a B&O audio or video system to turn off the remote to the speakers. All of this must be done with only one speaker plug in to power at a time. Otherwise one speaker will receive the wrong codes.
To unlock the pincode system
Each BeoLab 5 must be switched on – one at a time – before the pincode can be entered. This procedure is necessary because the Beo4 remote signals otherwise will activate all BeoLab 5 loudspeakers in the room, thereby sending them wrong pincodes.
1 Connect all BeoLab 5 loudspeakers to a Bang & Olufsen system – however, do not connect them to the mains, yet!
2 Connect one BeoLab 5 to the mains.
3 Press RADIO (for example) on the Beo4 remote
control to switch BeoLab 5 on.
The indicator light slowly flashes red and green.
3 Enter the four-digit pincode for that particular BeoLab 5 on the Beo4 remote control*. BeoLab 5 confirms each digit with a ‘beep’.
4 Repeat the above procedure for each BeoLab 5 – one at a time.
When the pincode is accepted, the indicator light shines green – indicating that BeoLab 5 has been unlocked.
If the pincode is not accepted, BeoLab 5 emits a sound signal, and you must start over again with the four-digit code.
If an incorrect pincode is entered five times, BeoLab 5 will lock up. In order to be able to enter the correct pincode, you will have to leave BeoLab 5 connected to the mains, and wait a minimum of three hours before attempting to enter the pin- code again. If BeoLab 5 is disconnected from the mains within these three hours, the timer will reset and upon reconnection a new three hour wait period will commence. After three hours, you will be able to make five attempts again to enter the pincode, before being locked out for another three hours. This cycle will repeat until the correct pincode is entered.
