I have bought a pair of beolab5
but do not know how to setup it. now, after pluging supply in about 15-20s, the light turn red then turn off.
so, what should i do now to setup this pair of beolab 5 ???
Help me :(
Help me :(
Sounds like normal behavior, according to the manual. If the light is red for a short while then turns off it means the speaker is in standby. How do you have it connected to a source component, and what is it/are they connected to?
You can download the manual here:
http://www.bang-olufsen.com/en/customer-service/product-support/sound/loudspeakers/beolab-5
Did you get a PIN-code from the seller?
What do you have them connected to?
It is normal if you are on SW 3.3
The soft ware is designed like that to reduce power consumption in standby.
Cant you get any help from your dealer?
Thank you so much for your supporting
But I've just wonder why, when typing Pin code for beolab5, there is no key signal sound feedback?
Somebody please help me. I have tried to set up pin code for my beolab5. I follow the steps in manunal document (P14). After the step pressing touch field button on top of the loudspeaker, which i want to active, then that loudspeaker confirm my selection with the sound like "ding-dong, ding-dong," . I have no idea with these signal sound.
Do you know what these sound mean?
and how can I solve it to continue active my beolab5 ?
Did you press the PIN code on your BEO Remote? In that case. the sound you hear is a confirmation that the pin is either rejectet or acceptet.
When pressing the pin on your beoremote the speakers will maka a sound everytime you press a button on the remote and after 4 correct presses it will make a sound as you describe.
/Ehlz
What signal do you feed to your speakers? CD player, MP3, ??
Who did you buy them from? If it's a dealer, surely he/she can help in person!
