Activating Beo4 remote with Beocenter 2300?
Hi!
I have a Beocenter 2300 and am trying to run it with my remote control.
Do i have to program the remote with the beocenter to get it working or do i have to reset something?
Nothing happens when i press any of the buttons on the remote. I have been using the remote for an Ouverture so i know the remote is working.
Maybe it is my beocenter 2300 that isn't working properly?
Best Regards
Magnus
Hello Magnus, and welcome to Beoworld. You will prbably find that the BC2300 needs the options setting. On your Beo4, hold down the LIST button and the OFF (red spot) button at the same time. You chould see ADD? on the display. Using the up\down, tyhen GO select OPTION?. Then using up\down again select A.OPT.  Then press 1, you should see the stand by light on your BC2300 flash a few times. This will reactivate the IR reciever.
Craig🙂
snajdarn wrote:
Hi!
Best Regards
Magnus
Hi Magnus
The BEO4 remote should work fine with your beocenter 2300 without any programming of the remote. Perhaps your beocenter 2300 has the wrong setup Option set. You should find the appropriate setup option in your installation manual for the beocenter (Option 1 or Option 2 should work, but there are options where the beocenter doesn't listen to the remote).
Option setting is SOUND, 1, STORE with the BEOLINK 1000 or A.Opt 1 with the BEO4
Best Regards
David
