Access Sources from Remote
Dear all,
I have two questions:
1. How do I access V.Aux from Beolink 1000?
2. How do I access the DAB Radio from Beo4 (on BS4)?
Many thanks in advance for any feedback.
Best regards
Spiros
1) SHIFT+TV = V.AUX
2) don't know for shure, but my understanding is, the sender list is mixed with FM radio, so access is RADIO
regards
Many thanks for the fast reply!!
kurfuer wrote:
1) SHIFT+TV = V.AUX
regards
You have me confused on SHIFT+TV in that none of my three remotes has a SHIFT button. If you could advise or clarify it would be of a great help. Thanks.
Fourth row from the top, in the middle....
Sure you have a Beolink 1000?
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Ralf
Wow! Thanks for the information. I was referencing a Beo4 from the orginal post, so it looks like I confused the issue. Thank again for this posting.
With Beo4 you need to add SHIFT (or V.AUX) command to your LIST.
We have all seen BL1000s with missing keys, but it took me weeks to notice that one of my BL1000s (got it with a BM4500) had two RESET keys! V.TAPE key was lost so the original owner had repaired it with "just some key" from another BL. I noted nothing wrong at first... 😂
