A.Aux in link room
Hello All
I have a BeoSound3000 in lounge with Lab4000's. I also have a pair of CX50's in kitchen on a Link Passive.
BeoSound3000 is in option 1 and Passive kit is option 4 as its open plan and commands used to "sneak" to the kitchen hence the need for the "link" command.
I have just installed an Airport Express to the A.Aux socket of the BeoSound3000 and it all works fine. I can only access this source in the kitchen by manually pressing the Passive sensor after first switching on A.Aux in the lounge.
Is there a way of opening the link to the kitchen via remote? I normally use BeoLink1000 in the kitchen but also have a Beo4 in the lounge.
Opman
does the passive have old software?
have u tried a mem instead of v aux?
Depending which SW version your BSd 3000 and Passive have,
using the BL1000 and pressing "LINK" "PHONO" might work.
Link + a.mem / a.tape should do the trick on a beo4.
Have similar setup and have the same problem with A Aux. Suggested Commands does not work.
Success :-)
Link + A.Tape on the BeoLink1000 does the trick.
The BeoSound3000 display shows the source changes from A.Aux to A.Tape but I still get the Airport Express in the kitchen.
Result.
Thanks for the suggestions
Opman
For the record, Link + Phono command to the Link Passive = N.Radio on the BeoSound3000
Opman
